TerryDean
- Pittsburg, TX
Update: The SuperLift AAL is 24.5" which fits between the clips on the leafs which will be staying. All I had to do is clamp near the clips then loosen the middle clamp and then put the AAL in.
Here's the new problem presented - The centering bolt which came with my AAL is fatter than the hole through my factory leafs. This is a problem. Closest spring shop is nearly an hour away - even longer by foot.
I was able to back the original bolt out but I don't think it will be long enough and I don't like reusing bolts anyway.
