joe_peters
- Grants Pass, OryGun
It just happened to my '96. Passenger side.
I plan to use grade 8 till I get OEM replacements.
I guess I'm going to have to buy a 90 degree attachment for my drill.
Get yourself a set of left-hand drill bits. Often times when you use them the broken piece of the bolt will back itself out. Easy-outs are aren't--break one off and you will have to GRIND it out.
Before you cinch things down with new bolts--make sure that the bolts aren't bottoming out in the holes. If they do, the engine mount bracket will slip up and down and take out the new bolts in a short time.
And I would use grade 5 in this application.
