- sacramento
Ruffstuff 1 ton tie rod end steering- inverted T style
parts mike TREs (better quality than ruffstuff)
the cure spacer
ruffstuff stabilizer mount
comes with the stabilizer if you want it
one 7/8" knuckle insert
maybe a second knuckle insert if I can find it
it has like 10 miles on it. hate to sell it but I wont use it
tie rod is 55" at the moment with adjustment left in the TREs and the drag link is 34.5" with adjustment left in the TREs as well.
to shorten a lot more than the TREs allow simply cut it down and weld in new bungs on one side of the tie rod or the drag link
it was installed in a hp44 with stock knuckles
260$ obo
im sticking with heims on the dana 60 simply for the 5th bolt hole going through the heims and through the lower knuckle for added strength in the high steer which will go away with TREs
the cure spacer
260$ obo
