RollTider
- Tusacaloosa, Alabama ROLL TIDE ROLL
I have a 89 XJ non abs, rear 8.25 stock drums, WJ booster and master.
All soft lines, master, calipers, and everything on the rear drums. The calipers are installed with the bleeder up, the drums have been adjusted out, and the master was bench bleed.
Rock hard peddle with the engine off but when I crank it the peddle drops. The brakes wont pump up and are basically ineffective till near the floor. It's been like this every step of the way. No amount of bleeding with different techniques and even got a vacuum bleeder. Assuming no air in the system would possibly be the problem? I've ran out of parts to replace
