heyhar
- PA (near Poconos)
I've come home from the yard with various combo valves, one to be the dissection volunteer. For all the hoopla, all it seems to be is a chamber for the brake warning light switch. There's the piston in the middle, and if it moves off-center, as in a fluid leak, it actuates the switch to illuminate the dashboard display. It actually did its job once in my '92, after the hard line to the rear failed suddenly. Of course, my foot going quickly to the floor told me that something was wrong! Oddly enough, after we fixed the hard line, replacing the soft line with it, the pedal feel was the best it ever was. And that was without bleeding the combo block.
Another thing I've seen is that the combo is different form drum to disc rears, although the part #s for the M/C in the XJ and ZJ are the same (the later XJ M/C). If I get around to doing ZJ rears on my '96 this summer, I'll be sure to grab a ZJ combo valve with it.
Although, if I get good results by bleeding my current combo valve, maybe I'll get to do more this summer than work on the HEEP. Last summer was inner and outer rocker panels and major floor pan repairs...Thanks Pennsylvania!
