outlander
- Columbus,Ohio
First off im not starting this thread to slam boostwerks....im not that way.
ok now it seems that these types of shift linkages work well on mainly auto trans jeeps and like to bind in manual trans jeeps due to the linkage geometry....I have a manual and tried every hole on the tcase tab and toyed with adjustments till I was blue in the face...
Boostwerks has good customer service and refunded my money all while I kept the linkage.
Good on boostwerks!
Now the problem was when I got into 4lo it wouldnt shift out unless I crawled under and moved the tab by hand because in 4lo the rod was straight in line with the top of the tab causing leverage to be applied down into the pivot point instead of up into the circumference of the shifter arc....
Solution?
The tcase shifter lever tab at the console has to be extended to get the leverage forces right and to make the rod sit more level
here is alot of reading on a very similar linkage setup which confirmed my early suspicions of geometry being off causing binding in 4lo
(See below)
Good on boostwerks!
Solution?
(See below)
