DanZ
- hamilton, ontario
Can someone help me out here please
1996 Cherokee Sport
My pedal goes right to the floor.
I am bleeding the brakes. I blocked off lines coming from the master cylinder and the pedal is rock solid. I just blocked off the rear and the pedal hits the floor again. So there is air in the front brakes. I bled them several times at each wheel and the master cylinder but the pedal is not getting better. If I pump the brakes and build up pressure I have a pedal but as soon as I let the pressure off and try it again it goes to the floor.
Any suggestions? I am pretty sure it must be air in the lines somewhere that just won't come out from normal bleeding. Does anyone know someone with a pressurized brake bleeder or have any other ideas?
I am really stuck here.
Thanks
1996 Cherokee Sport
Thanks
