I swapped axles from a ABS D35 to a 8.25 with no ABS. I need to bleed my brakes but is there a different procedure? Searching doesnt bring up a conclusive answer.
In my FSM there is a special procedure for ABS brakes (which invloves cycling with the ABS pump), in addition to the regular procedure for base brakes. Now that I have disabled my ABS (by pulling fuses and sensors) can it be bled normally with good results? Reading the other posts on this subject showed conflicting arguments...
Looking for definitive info and actual experience on this, thanks
