- Middle Tennessee
I would recommend Nokian Vatiiva AT's. I've run them on several vehicles including an XJ. They do well in wet, snow, and ice conditions.
I am so pleased that there is finally a negative post about these truly terrible tires. I noticed all the same things, at 30 psi, throughout the entire time the tires lasted, which was not long at all.
So 2 bad reviews out weigh 48 good ones? Unless you are used to running toyo proxes the tires should have a lot of traction. Most BFG AT's I've seen can go 30k plus miles with ease. Were yours used or what?
my dad had a set on his truck that lasted almost 70k miles
BFG AT KO, bought them new, a while ago, probably 6 years. 31x10.5. They lasted about 20,000 miles before the cords were showing. Everyone I know who has had them has had similar results, so I have no idea why people on here like them, unless they changed to a not-so-soft compound. Professionally aligned, and I did regular 5-tire rotations. 30 psi. They performed terribly on and off the road, not that they would be expected to do good in deep mud, but I would have expected them to be quiet on the road. I never tore a sidewall on them. I won't buy again, but I suspect something has changed, or I got bad ones. I used to go out looking for mud, which most likely has a lot to do with my hatred of those tires, mud is unavoidable around here. I'm happy with the FCIIs I replaced them with, which are conceptually similar, yet they clean out better if I accidentally find some mud, but they were at least as expensive as the BFGs.
I agree with the op,
I had a set of 30X9.5X15s on my old Ford Bronco2 & they sucked on the road, On the beach they were good.
On road, I was afraid to drive the truck in the rain!
I've got 31x10.50 and pressure is 34-35psi
I don't know the exact miles on them but I'd hazard a guess at maybe 30,000-60,000 miles, I don't know exactly.
Hmm I may have been wrong about the mileage. I got the lift put on in late Jan of 2008 and I have put around 5,000-8,000 miles on it since.
