MrShaft696
- Blue Bell, PA
Why the hell would you want put 44s/lockers/chromos/CTMs in a rig with 30" tires when the 30 with some ABS shafts will probabaly never ever break and the 8.25 will be fine as well on 30s? even with lockers?
Here is what you do:
lock the front and find a 8.8 with LSD since itll be cheaper than locking the rear and stronger, just weld the tubes and get a HD cover .
swap in ABS shafts up front with new spicer 760 U joints and use some full circle clips.
call it done.
please dont build an XJ on waggy 44s/chromos/ctms/ lockers just to run 30" A/T tires. I think it would offend many people.
sort of second this, I run abs stub shafts and tacked caps on locked 35's & I hammer the jeep hard. A 29spline 8.25 is a pretty strong axle as well, you would have to drop it off a ledge at full throttle bouncing to break it on 30's.
