On to the install... First thing I wanted to do was install the lift and tires before installing the axles. I knew the upper shackle bolts would be bad (have never been out), and I knew the RE leaf bushings were shot, so I wanted to deal with all that junk first.
RE leaf bushings completely destroyed, replaced with Stengel Bros rubber counterparts as recommended here on
. Pretty easy swap, considering. The basic approach was to push the rubber out, and then slice the outer metal with a sawzall to break the seal, then press in the new bushings with anti-sieze. Pretty straightforward
The upper shackle bolts were much more difficult. For those we had to cut the bolts flush with the body, then deal with the leftover nub. In both cases we ended up having to drill through the old 14mm bolt enough to tap for a 1/2" bolt for the relocation brackets. If I ever want to use these for 14mm again, I will have to drill more and tap again (should be able to).
The next day I got the shackles and relocation boxes installed. The front was easy enough, just drop the axle, pull the springs, and replace the stock isolators with the ACOS to get the jeep level.
The PO was in the process of converting the rear to a triangulated 4-link when he sold it, so before I could go any further I had to get the brackets and truss chopped
One thing I found was the tube was warbled from where the PO had welded the 4-link truss, so it was very difficult to get a level reference. I ended up using three jack-stands (one for each end and another for the yoke) and leveling the three points as a triangle, setting the yoke face to zero degrees, and then setting the perch angles relative to the yoke. This got me to almost exactly where I wanted, but I am off by about +1 degree at current height (dropping the rear should lower it back to the desired angle). No pics of the setup or welds, sorry
For the front I didn't have to do much, just tap for the coil retainer bolts and tap in the slotted washers.
I also tried to install the RE drop brackets, but I was not able to make my JKS LCAs short enough to fit between the LCA and drop bracket holes. Instead I stretched the front a little further out (about 17" on the LCAs and 16.75" on the UCAs) to help center the wheel, and also cut another 1" from the fenders to give more room.
