Slo-Sho
- The 2nd most regulated state.
I have a Diode type battery isolator (Sure Power ind. 160a) with one input and two outputs. From the bits and pieces I've read this type of isolator drops about .6 to 1v through the diodes due to it's design.
I have a 90 Renix which originally had the Delco CS-130 105a unit w/ internal voltage regulator. It is now gone in favor of the 136a Nippondenso unit with an external voltage regulator.
My question, Is it a good idea to connect the "sense" terminal of the regulator to one of the batteries so the voltage loss is made up for? Will this alternator be alright long term charging at 15V+ all the time?
