bastard pack info
bics90xj
I used Dodge van leafs minus the overload and bottom plus xj bottom spring.
shackles are 90s gm truck. I got some lift but not as much as hoped. Do the s-10 springs have alot of arc? Will adding more long leafs get more lift?
MJ springs will help provide lift. The main leaf will work as a full length add-a-leaf. Use the the next 2 leafs and use your XJ bottom leaf.
This should give you more lift. The Dodge van leaf does a good job of correcting the shackle angles.
