- Houston, Tx
My 94XJ currently has an 89 front axle, brakes, etc. A couple months back we converted this housing to non-disco, and re-did the ball joints and unit bearings at the same time. Less than a month after I think I bent the axle as its been leaking diff fluid from the tubes pretty frequently.
I've got my eye on a 99 HP30 to pick up to build.
Is there any benefit to the 99 brakes over the 89 ones? Is it possible to use those ball joints I just put in the 89 housing in the 99's?
