Rod Knee
- Grand Jct., CO
I would err on the side of having shorter shocks myself. Its been described to me that you get better traction on compression than droop, which makes sense to me.
tayman said:so... what is better then? Bumpstop and lose a little over 2" of up-travel? Or get shorter shocks and lose downtravel?
XJ_ranger said:cutt off your OEM bumpstop tower, add 2.5" of tube, weld it back on...
TNT said:Here's my thoughts...
If your tires didn't rub before you switched to longer shocks just relocate the lower mounts down 2.5" or 1.5" and use one hockey puck.
Cut your stock mounts off and build what the following picture shows.
BlueCuda said:The shock mounts are much stronger than people here are making them out to be. Since i put my 8.8 in and moved my shock mounts my rear shocks have been to long. This has been about two years ago and I have just been to damn lazy to fix the problem. I have bottomed the shocks out HARD hard enough I thought they were going to come through the floor. The shock mounts upper and lower are just fine. By no means is it a good idea to run shocks to long but the world will not end and the shocks will not come through the floor and kill your children in the back seat.
