Mitchen
- Gresham, OR
im still thinking its the coil. when mine went south it would do the same thing. pop and backfire when warm then eventually it just wouldnt start. had spark, just not strong enough to run the motor. you can have it tested at most auto parts stores. i would check that before getting too deep into this.
KISS. keep it simple stupid.
good luck
well the motor is turning over very fast i have been charging the battery i am going to go pick up a coil tommorow afternoon i have to work tonight. and that sensor i found hanging is the knock sensor.
i usually dont try to start it if the batter is close to the red
nothing is melted or shorted that sensor just ripped the wires out. will that cause it not to start?
