Besides the problem of it being a BA 10/5, what internally would causes it to pop out of reverse at random times? (it pops out of gear unless I hold down the shifter sometimes)
IF it is hopping out of gear, its time for a rebuild, it is worn out the syncros are shot and or gears are shot. basically it was a stupid question that deserved a stupid answer
I was just checking b/c I was thinking rebuild myself. Not that stupid of a question. Sometimes simple adjustments can be the answer and sometimes not.
Dont waste the money to rebuild teh french POS !!!!, search and replace it with a better trans, cheaper and ten times as strong...use the lil search function for ax5 or ax15 for swap out info, you will be miles ahead
