Lawn Cher'
- Westampton, NJ
You ever watch that Hoarders show on TV? I've become inspired to get rid of some of my stuff.
The following axles are available:
XJ D44 rear, 4.56 gears, full spool, u-bolt pinion yoke, thick cover
no brakes on this one, but I do have parts to piece together a disc setup
Scout D44 rear, nothing in the pumpkin, just housing & shafts, no brakes
early Bronco D44 front, empty housing, radius arms & track bar
I have a box of parts to convert it to disc brakes as well as some poly radius arm bushings
full width Ford 1/2 ton high pinion D44 front, has the cast wedges, empty housing
Asking $550 for the loaded XJ D44, $100 each for the others. Located in Westampton, NJ (NJTP exit 5.) I have an engine hoist to assist with loading. Work smarter, not harder, Daniel-san.
