Fozzy_Bear
- Norfolk, Va
Hi all
I have an '89 XJ with a quarter-million miles on it. The front D30 is nearly dead and the rear D35 aint anything to write home about either. Also, this is a 5 speed, so I was going to buy some pretty low gears for it since I am a n00b to wheeling.
Well into that situation came an oppurtunity to kill about 4 birds with one stone when I bought a new set of axles. I got a front D30 from a 96 XJ (the strounger U's and solid shaft) and a rear D44 that has the shock mounts raised and the perches set for 5" of lift along with a Disk brake conversion. They have 4.88's installed in them and the front has a locker. These axles came off an '87 XJ, so they should be about as plug-and-play as I'm ever going to find.
So I got a 3 inch lift kit and I'm going to install the lot this weekend. I know the perches are set for 5, but I figure I can see if 3 works, and if not, I can add spacers/shackles to get to 5. I'm only planning on 32" or 34" tires at most, and so a 5" lift just lifts my CG for no reason.
OK so my first questions is:
Am I on the right track so far? Is ther any flaw in the basic plan tht you can see?
The next (big) questions is:
What am I gooing to need in the way of consumeables? I figure I'm going to need a couple of bottles of brake fluid, a couple of bottles of PB blaster (* see below), a whole $$$tload of shop towles, a grease gun, a few air-wrenches. And, of course, enough beer and burgers for anybody I can con into coming over.
Anybody who has done this before: What Am I forgetting?
* - And on the topic of PB Blaster, I hear that I should start a few days early and hit the bolts over and over before the actuall day. Could somebody please tell me exactly which bolts I should be sure to get so that I don't miss any?
Thanks
Thanks
