You need to come up with and install the correct seal, and there are about a half dozen seals that 'might' be the correct seal. I used all of them without long term success, and then pop'd the carrier out and ground the space behind the passenger side bearing to take an OEM non disconnect seal. Works like a charm.
If you want to try the easy and not so great way, here are the seals we tried.
