Is it dangerous to use a 3 jaw gear puller (5-10 ton) to remove the hubs? Of the many techniques, this one is rarely mentioned. I saw it on the jeep.off-road write-up. I rented one from AZ... looks very easy... but I worry about the driver pin mangling my stub axle (although the end of the axle appears to have a recess that is perfect for a puller (the, uhm, "pointy" end of the driving pin). Is the stub axle "hardened"... perhaps I should stick an old socket on the end just for insurance.
Is pulling on that outer flange (where the studs attached) bad for the bearing? Even if it is, is it OK if I intend to swap in a shiny new hub when I finally get this old one out?
I'm hoping the socket/extension/spark plug wedgie maneaver will work for me. But I do have this cool puller here and it just looks like so much fun (can you tell I've never used a puller?)
