No the Detroit Electrac is not a good unit. besides. its not even available for the D30... hello?
the pros and cons... in 2wd both are pretty much invisible on the street. if your going to run a LS then the best one is the truetrac. the lockright, ez locker, quicklock, aussie locker are probably the noisiest units available. there is some noise/ratcheting on the street when turning even in 2wd. the no-slip is an awsome unit but the springs can go bad after so long.
If you want a LS then the truetrac is the way to go. if you want a locker then the Detroit is the way to go. if you want the best of both worlds then the ECted is the way to go being a LS and a locking and its cheaper than the ARB. up in Portland, i'd probably run a detroit personally and learn to drive it in adverse conditions. or else I'd go with a TT. If I had the $$$ i'ld run the Ected.
