DirtyMJ
- Prince George, BC
How much torque can you put into an AX-15 reliably? Or, what are they rated for?
I'm assuming it's under 300ft-lbs.
I think the NV3500 from a GM application will already have the GM bellhousing pattern and should have the same output as the Jeep NV3550.
How would the NSG370 6spd compare to the AX-15? I think I read of a couple people trying it TJs, why couldnt someone do it in an XJ? It would take a lot of fab work, but would it be worth it?
It's rated for 300ft-lbs on the dot. Not sure if I trust it to survive 275-280ft-lbs continuous (at 1800rpm for that matter). It would have the bell housing that would bolt up to the other adapter... I think GM used a different spline output though (32 maybe?), but perhaps I should look it up.
The Jeep NV3550 is used behind the VM 2.5 CRD in the KJ. The engine torque output is ~270 ft-lbs. Thats factory. If Jeep engineers threw the NV3550 behind a diesel engine with 270 ft-lbs at whatever low RPM it tops out at and expected it to last any length of time I suspect it will be fine running ~275-280.
A CRD probably out-revs my clanker. But that is a good point. I might have to hit up the libby forums and see if any of them drive them hard enough to blow their trans up. After all, they did use a BA10/5 Peugeot behind the 4.0L in the past, so I have little faith in some of the 'engineering decisions' of the Jeep brand.
Actually, the only offered automatics in the states, and apparently the 545RFE is a POS at that. I will have to look abroad.
