Digger87xj
- Buffalo Creek/Lakewood CO
You will get your answers at the connector for the fuel pump when you test for power and ground.
jump the relay and put your ear to the open filler neck
if you don't hear the pump get underneath and disconnect the fuel pump harness, test for 12v on the darkgreen/white wire
test for ground on the black wire. This ground leads to a terminal ring behind the left rear compartment trim.
if all test good, i.e. you have power and ground, time for a fuel pump module.
