lamula
- El Cajon Ca.
I got well into my install on a d35 when it came to the measurement of the spacer to center shaft they call out a max of .020 inch I,m at .024 and the center gap between cam gears they say max. .170 inch I,m at .182
soooo? What to do now, I can't go back to the old gear set as I had to grind out room to fit in the Aussie. I'vd e-mailed aussie install help but they most likley wont respond until the middle of next week.I may be able to buy thicker thrust washers to go behind the axle gears but I'm not sure if that is possible.
Anyone with a similar experience?? PLEASE clue me in.
