SnowboardinXJ
- Honolulu,HI
98 XJ, 4.0, 4WD AT, 2dr Sport
My ignition switch failed and when I removed the ignition switch the "barrel" that turns the ignition switch was broken. The assembly it is a part of is integrated with the steering lock plate and is mounted under the steering column. The lock cylinder is on the right of the steering column. The ignition switch is on the left of the steering column. The broken piece is mounted under the steering column and connects the lock cylinder to the ignition switch and also engages the steering lock.
Looking for parts has been rough, the only thing close is an entire steering column(+1000$):rattle: I have been searching ebay and amazon with no luck.
What I need:
-What is this specific piece called?
-Does it have a part number?
-Where can I get it as an individual piece?(tried junkyards before but they are normally only willing to release large assemblies(i.e. the steering column)
What drawings I have aren't that specific so I could use the help.
I can start the jeep by turning the ignition switch with a screwdriver for now with the ignition switch dangling between my legs. Would like this situation to be temporary. You guys are the best.
What I need:
