Femsa is a spanish made imitation York compressor. I dont know if they were ever OEM for anything, but you find them in some 70's pickups and van's. If I had to guess I'd say they were just a cheaper replacement for failed Yorks, but i don't know that.
that looks like the york compressors that came factor on a bunch of ford trucks and vans. they were also a dealer installed AC system on a few others, but the coolest thing about them is they make the best compressors for on board air you. should check if someone makes a converson, i've only saw them offered new in kits.
Thanks for the replies, fabricating the brackets to mount onto the engine isn't going to be a problem. It's just that I want to know if this puppy is worth it? Also if I could swap clutch pulleys that would be sweet.
