tbburg
- Scottsdale AZ
Hint for a low-buck exhaust build:
Instead of buying mandrel bent 45s and 90s, have a local shop bend you some 55s and 110s out of pipe 1/4" - 1/2" larger then the straight pipe you are using.
example: if you are running 2" pipe, have bends made from 2 1/2" pipe. Cut the "uncrushed" ends off the bends, and the diameter of the bend will be close to the diameter of the straight pipe you are using.
