tchase
- Nova Scotia, Canada
As some of you may know I've started racing my old '91 XJ. After being quite competitive in the 2 events I ran this season we're really hooked now. Here's the class rules for the class I'm currently running:
4 & 6 Cylinder Stock Class
-Anything that is factory built stock, full stock body, stock running gear, or any combination of stock components, must be located in stock location.
-Body lifts allowed for tire clearance.
-Box must have all steel construction, including headboard and floor. Made and removed as one unit. Must have exterior OEM panels or replacement OEM panels.
-May run open exhaust.
-No aluminum carburetor intakes except for OEM fuel injections systems.
-Factory OEM aluminum heads may be used in conjunction with factory OEM fuel injection.
-Shocks must be OEM mounted.
-No after market add ons except carburetors and headers (ex: no fuel pumps or ignitions)
-Street DOT tires, no cut tires
I'll probably stick with that class for next year but will eventually step up to the following:
4 & 6 Cylinder ProLite Class (Combined)
-Full stock body or fully caged.
-No nitrous or superchargers, induction systems or boosters.
-Street DOT tires, no cut tires.
Over the winter we plan to cage the beast so the first question is this; I've got an old 2wd shortbed commanche that's beyond saving for street use, would this be a better candidate for a racer than the XJ body? Is the gain in wheelbase worth re-wiring the whole truck for the HO drivetrian? I scored a '93 country last week that is tremendously rusty but has a great drivetrain including an 8.25. I also have a buddy who has an old 258 he said I could have so I'll be building a stroker if I'm gonna step up to the pro-lite class. Budget is tight but we have some sponsorship and more would be available if we can build a competitive rig for pro-lite. I'm currently going over the great thread on pre-runner type suspension but any other input and tips would be greatly appreciated.
