1) Have the tech plug his hand held into the OBD port and turn it on. A menu screen comes up with a bunch of info. Select YES to go to next screen.
2) On this screen select menu item 1, "DRB III Standalone" to go to next screen.
3) On this screen select menu item 1, "1998-2005" to go to next screen.
4) On this screen select menu item 1, "All" to go to next screen.
5) On this screen select menu item 5, "Antilock Brakes" to go to next screen.
6) On this screen select menu item 9, "Miscellaneous" to go to next screen.
7) On this screen select menu item 2, "Set Pinion Factor" to go to next screen.
8) On this screen there are a several tire sizes and Other. Select menu item 8, "Other" to go to next screen.
9) On this screen there are two items, an Axle Size, (9.25" on the 1500's and 10.5" on the 25/3500's) and Other. Select menu item 1, "9.25" Axle" (10.5 in your case) to go to next screen.
10) You have now arrived at the point in this process where you will enter the revolutions per mile for your tire size. Select the menu box for RPM. It will indicate 400. Here is where the tech will change the revs per mile with either the up or down arrow. It will take a while to go from 400 to 604 (for the BFG 315's) so be patient. As you are waiting on him to finish, take this time to let him know that he shouldn't charge you more than say $20.00, especially since you trained him on this procedure.
11) The last step is to select "OK" and the changes will be excepted, then the hand held will display "Reprogramming Successful".
