- Coshocton, OH
red97xj i dont think anything bigger than 3" will fit, because it will hit the hood when you close it. besides the throttle body isn't three inches around anyway. so it would kind of be a waste of time to get it to fit. but if you used the home hvac duct that i described earlier you could use four inch and just oval it some, for a better fit. i still might get some and change it over to that because i think it would make for a cleaner looking install. if i do i'll post some more pics also it hasnt been very hot here sence i did this nor has it rained so i still dont have any comments on that yet. but i can say that it has more a$$ in the hills at interstate speeds, and there is some hissing noise when you first start it, butt that goes away in a few min once it gets some warmth in it. although that will probbly last longer in the colder months. also i didn't seal up the air box compleatly, the drain holes on the bottom are still open. so if any water would get in there it will drain out. i didn't seal them because i don't plan on driving through water that deep. i did this more or less to keep splashing water out.
