- Indiana-Missouri
rich....
I've been neglecting to get on this post, cause moab is so close, and my input will cause you more work.
there is NO REASON to have your tracbarmount so high above the axle tube. In doing so, you've opened up a can of worms you are dealing with now. The situation you are in now, is exactly the one I was trying to help you avoid by trying to keep you from going to 8" in the first place, but now that you are there, lets deal with it.
I highly suggest you remove that tracbar bracket, and place a new one so that the tracbar meets the axle just over the axle tube, say between 1 and 2 inches. Buy a tried-and-true aftermarket tracbar fromt he vendor of your choice.
install a non-exotic "over-under" or 'over the knuckle" straight-link tie rod and drag link.
the stringline angle of your tracbar and draglink need to be parallel.
I'm gonna sound harsh here, but its for your own good. You simply do not have the time to be screwing around with experiements, on a vehicle you are NOT towing, in the timeframe you have, with the limited offroad modifications experience you have.
suck it up, we've all been there. There are quite a few of us that have to bust some serious balls to make it to mAOb. The way I see it, the above is your best hope for making it. The last thing you need, is to try to patch or save your current design, so that you discover without having made it to west new york state, that you have to turn around cause your rig is undriveable
