Because toe in is adjusted seperately from the steering wheel centering adjustment.WheelsUp said:Please explain to me why.
The toe is adjusted by turning the steering tube running from the left outer tie rod end to the tie rod end mounted to the drag link.
Steering wheel center is adjusted by the adjuster sleeve between the end the draglink and the pitman arm tie rod end. It is above where the tierod end attached at.
Your toe in can be perfect and your steering wheel can be off center. You can adjust the steering wheel to center it later and it won't change toe in...
