- Torrance, CA
But you'll get a wicked head rush.
johnny said:CO2 actually = carbon dioxide
I beleive O2 (oxygen) and CO2 have different expansion/compression ratios which I think is why some people are using co2
Your not missing anything, there is a lot of confussion in this thread.azdesertrhino said:OK, this is getting really confusing for me. If I understand correctly we are comparing compressed air in a tank (like you get at a gas station) compared to CO2 (carbon dioxide). Am I correct so far?
Now compressed air is just "X" amount of compressed air pressure in a tank where CO2 is in a liquid state that boils off as vapor is released and maintains a pressure unless you blow off a lot of vapor and your tank gets real cold and the CO2 can't boil off.
If I am reading this right, there is no way a tank holding compressed air will fill as many tires as a tank the same size holding CO2, or am I really missing something. hasta
Your correct but co2 is a liquid, not a gas when compressed to 150# at 70 deg'sSBrad001 said:Actually, the rate of expansion for both O2 and CO2 is same, they both follow the Ideal Gas Law: Pressure = (nR*Temperature)/Volume. The advantage to using CO2 versus just plain old compressed air, is that CO2 is a relatively stable gas that doesn't oxidize anything except under very specific reaction. On the other hand compressed air drops moisture as it is compressed and contains high amounts of O2, both of which play havoc with alloys and rubber compounds.
In some high end tire shops, they have taken to using compressed N2(nitrogen) since it is even more stable and increase the longevity of of the rubber compounds with in the tire. The problem with this though, is that once you pust compressed air in with the N2, is that you've just defeated the purpose of using N2 in the first place. . . . .
Tangent done now. . . .
langer1 said:Your correct but co2 is a liquid, not a gas when compressed to 150# at 70 deg's
Oxygen is only in liquid state at -300 deg and about 250 psi.
Nitrogen is used in tire shops because the large molecules will not leak through cast aluminum wheels like air.
Not quite. At 70° F (I assume you're talking Farenheit) CO2 must be compressed to about 900 psi before it will turn to liquid.langer1 said:Your correct but co2 is a liquid, not a gas when compressed to 150# at 70 deg's...
Your right, my co2 tanks regulator only shows the reduced pressure not the tank pressure.dmillion said:Not quite. At 70° F (I assume you're talking Farenheit) CO2 must be compressed to about 900 psi before it will turn to liquid.
