Redcbr007 said:
No, its not a tuning issue, especially since I live about 5 min away from fox themselves who valved and tuned it for me...call them if you think it was tuned wrong. It was a 80/80 valving, about 400 on the psi and almost 300cc of oil, it held the xj up ALMOST to the ride height, but they said it would gurnade after it heat up, so I went coil-overs.
Good info on the shock settings, but what does your rig weigh and what were you shooting for as ride height?
I never said I thought anyone was wrong! I just think there is something else going on besides "they don't work on an XJ"
The heat issue would if anytihng cause fade - I doubt you could truely rupture one of these shocks due to thermal expansion of nitrogen gas - if so why would Fox list 500 psi as their max pressure - also what is the plan for these - desert racing, prerunner, rockcrawler, some of everything...
Neil: - the spring rate is controlled by the gas - the oil level sets how fast the rate begins to become progressive - since you have a closed chamber with a fixed amount of gas there is no way the rate be anything but progressive...
If you look at the volume/ pressure curve you will see the ride height pressure is just that - the PSI at ride height, in any other position the volume has changed and the PSI reflects this - so your initial charging pressure is not the pressure in the shock at ride height (when the PSI changes the force transmitted to the shaft from the piston reflects this change...) (PV=NRT)
This is the same priciple their (fox) bump stops use to function - as you make a set amount of charged gas go into a smaller space you need to impart a larger and larger force to compress each additional inch - it is not a linear relationship...
A coil spring or a leaf spring acts the same way - in a coil spring (XJ type) the smaller windings at the top allot for a softer initial rate and then the main coil transitions into the primary rate - as the windings begin to touch each other the rate begins to increase dramatically... With a leaf spring you are transitioning different leaves that all represent distinct spring rates - as they get added together the total spring rate begins to get higher...
Matt
You can see on this chart from POR by Billavista and Dave from Polyperformance - that the spring rate increases dramatically as the chamber volume shrinks...
http://www.pirate4x4.com/tech/billavista/PR-Airshox/index.html
