xuv-this
bondo afficianado
- southwest VA.
so you wired it to force each wheel independantly? cause' the controller box in the pic only worked 2 wheels at a time, like left side or right....?
I designed and built my system long before the idea of "air bag kits" was around.xuv-this said:so you wired it to force each wheel independantly? cause' the controller box in the pic only worked 2 wheels at a time, like left side or right....?
Gojeep said:The rear airbag kit I showed have no controlls at all. You just set the pressure with a air hose at the servo or where ever and thats it. This is a very simple system for those like me that would only be changing it when loaded with a trailer. Also allows you to level the lift left to right as well due to separate air lines. You could fit more controls to if you had on board air etc. One of the guys on here have just fitted a set and was thinking of adding a simple solenoid so that they are independant for the highway giving reduced body sway but then flicking a switch so when off roading the air on a compressed bag would travel across to the other helping in pushing it down. Justy a simple tee piece in each line that comnected the two together with the solenoid inbetween would be all that was needed. You would even have to have on board air to do it.
xuv-this said:HOOWWLY crap! i seen it all now. so i knew about the "universal spring helper kits" but had no idea about the 4 link. so there IS a kit to lower the rear. wow.
so you guys who are running the fabbed airbag rigs; honestly i could never see why someone would want that over springs, so could someone enlighten me? like doesn't it get kinda annoying having to constantly push buttons while goin' over the big bumps?
Then just get air shocks if thats all you want... I've got airride all the way around on a lil lowrider vehicle and i love it, not that that really matters,Indertdxj said:I just want airbags to lift sag on springs when fully loaded.
Indertdxj said:Thought its better to bring back old thread and info than to start a new one?!??!?!?!?
