HaleYes
- Clay County, IL
CSF Radiator is on the way to my house. Hopefully, mine will hold out until it gets here.:laugh:
Hale
Hale
5-90 said:So do I - have for years.
Granted, I don't much follow motorsports - but isn't an advantage of an aluminum radiator vice copper reduced weight for the same size? That means more of the acceleration is going to be used to actually accelerate, due to reduced mass (and therefore reduced inertia.) I think you'll find that most "motorsports" vehicle also run straight water - water is a more efficient thermal conductor than ethylene glycol, and therefore will work with the radiator and engine to conduct more heat. EG is added to automotive systems to prevent freezing, not to improve cooling.
I also hear you on the metric stuff - I still think in inches, and probably always will. Fortunately, there are "one-button conversions" on my calculator - I try to remember the conversion factors myself, but I've been hit in the head an awful lot, and can't trust my memory implicitly on some things any more...
Wanna know why?imis_idora said:Yeah. That's why every single person in any kind of motorsport runs an aluminum radiator.
BINGO!imis_idora said:Copper is heavy, aluminum is light.
imis_idora said:Do you think John Force has a copper radiator?
imis_idora said:A 2 core aluminum radiator will out cool a 4 core copper brass radiator all day everyday. Why? Airflow. It is easier to flow air through 2 cores than 4. So why would an aluminum 2 core out perform a 2 core copper radiator? Because copper is weak. After it bends and flexes it will flow very little air or water.
imis_idora said:All the wires in your Jeep are made of copper. Why? Because it is easy to bend and has all the properties that GoJeep spoke of.
imis_idora said:Are your rims made of copper? Of course not they have to be strong.
imis_idora said:Is your stereo amplifier made of copper? Nope it's aluminum because it has to be strong and dissipate heat.
imis_idora said:If copper is so great why can I buy an aluminum head and run 11 to 1 compression on pump gas or use an Iron head and run 10.5 to 1 compression on pump gas? Why can't I buy a copper head and run 13 to 1 on pump gas? :sure:
5-90 said:I think you'll find that most "motorsports" vehicle also run straight water - water is a more efficient thermal conductor than ethylene glycol, and therefore will work with the radiator and engine to conduct more heat. EG is added to automotive systems to prevent freezing, not to improve cooling.
5-90 said:Um, Dingo - a lot of intakes are made of cast aluminum - to bring energy costs down. Intakes don't have to handle the heat that exhausts do, so they can use aluminum (which melts at a lower temperature) for the intake - which also makes the intake lighter (reducing vehicle weight) and aluminum machines more readily than iron (which reduces CNC cycle times and production costs.) And yes, I've also seen a plastic intake on a production vehicle - 1995 and 1996 Neon (both owned by one of my boys.) I'm not so sure that plastic was such a good idea for something like that, but what do I know? This thing was designed by Mitsubishi....
5-90 said:Ah - interesting. I shall have to dig around on that subject further. Meanwhile, I stand corrected.
If you want to make the XJ radiator more efficient in general - redesign it for a "downflow" pattern rather than a "crossflow." This have the effect of exposing more hot coolant to ram air at any given time, allowing for more heat ejection by the radiator. Anyone want to try to tackle that one? Radiator flow patterns and design play as important a part as material used - if not moreso.
Cracked housings leaving you stranded.fubar XJ said:Too late, I ordered the Flow Kooler pump yesterday. If it turns out to be a POS, I'll replace it with a Hesco when it fails. Were the Flow Kooler pump problems of a catastrophic nature, i.e. stranded on the trails with a blown pump, or more a durability issue, i.e. wearing out prematurely?
imis_idora said:Yeah. That's why every single person in any kind of motorsport runs an aluminum radiator. Do you think John Force has a copper radiator? How about Jeff Gordon? Copper is weak, aluminum is strong. Copper is heavy, aluminum is light. A 2 core aluminum radiator will out cool a 4 core copper brass radiator all day everyday.
Because copper is weak. After it bends and flexes it will flow very litte air or water.
Think of it like this.
Is your stereo amplifier made of copper? Nope it's aluminum because it has to be strong and disapate heat.
TRCM said:Or you can do like I did, and purchase a dual pass rad....the water in my rad (on my offroad rig) passes thru the cooling airflow twice...works very well by the way.
