Green Mesa XJ
- Pensacola, FL
I've had these jeeps need to be jumped to get started. Don't remember how it went after I replaced everything but the evaporator in dash. Could just be the switch.
But it's over 25 years old.
I used the conversion kit from Walmart. There are all kinds of things about r134a conversion, I've done it by the book and redneck, both will work.
Um, you could see if the guy would try to charge it with the compressor jumped then undo the jump to see if the pressure switch works.
That how I got mine to charge for sure when it was on the way out. Like I said I can't remember if I had to do that when I went new, by then I had a set of gauges and vacuum pump.
