srmitchell
- Mckinleyville (Humboldt) CA
All the yokes are completely tight. (I should probably double check the front one again though.)
I've had a hub kit on mine along with 4340 inners and while it was a lot of money, it really made driving it on the street a pleasure. No vibration no noise.
For Sean and mako my day, I certainly would not give up or sell the rig. I would get a hub kit any day before doing that.
New pinion bearings? how are the carrier bearings? any odd wear on the gears?
so you pulled front shaft, and no vibes. put front shaft on the rear, and no vibes.
what is your DS angle up front? 0 degrees is bad, but with only 3.5" lift, your DS angle shouldn't be too steep, maybe 12* or less ? . get that pinion pointed as high as you can while still maintaining at least 4* of positive caster, obviously having as much positive caster is important. if not more. in the rear its more important to have pinion 1-3* below DS angle, the front you have a little more room.
you have swapped front tires to rear and vice versa? you are 100% positive they are balanced?
I'm surprised you can't balance out the vibration at the CV end - the CV H-block itself must be unbalanced or non symmetrical in some way. Of course, I don't think anyone actually balances those parts individually, just the whole assembly.
yeah... the other part of the theory of how CV joints avoid vibration is that the two ujoints are always perfectly in phase and (theoretically) the centering ball setup keeps the angle on them exactly the same. What that means is that there isn't any rotational speed difference between the tcase output yoke and the driveshaft tube itself, which significantly reduces vibes, but the H block itself still speeds up and slows down with respect to the tcase yoke and the tube. If the H block is unbalanced (i.e. its rotational center of mass isn't exactly on the axis of the ujoints) it'll increase the vibes, but now that I think about it, the vibes you are feeling are probably mostly from the H block itself speeding up and slowing down as it rotates. No real way to fix that other than going to a ball and cup style CV.Have tried two used shafts re-balanced, one with a new CV assy, a stock shaft and then a complete new shaft. Wish that was the problem but so far, different shafts have not made much of a difference. All the shafts were built by different shops.
I'm running out of things to check or change. Wonder what changing the front shaft's phasing would do?
I'm open to suggestions.
CV joints are nothing more than two couple u-joints and they too suffer the same speeding up and slowing down situation, when spinning, as a regular u-joint. The advantage is the angle change being spread over two u-joints instead of one. 15.5 degrees is 7.75 degrees of change per u-joint, excessive according to every chart I have found, when spun over 2000 RPM. My freeway cruise RPM, with the 4.56s, is 2400-2600.
This would not be a problem for a trail only rig that that rarely sees 60 MPH but for a DD, that is freeway driven, it is a major annoyance.
Hmmm, 35"s would push the vibs back over 70 MPH....it's endless.
It might be easier and cheaper to buy a stock XJ and use it for my DD.
I had mine balanced to 3200 rpm. Their standard is 2800.
