99NCXJ
- Belmont, NC
AW4 tranny 21 spline output from 89 xj I've never ran it but was told it shifted fine. 50.00
xj/mj steering box pulled from 89 jeep. 25.00 each
(2) stock xj cross members 15.00 each
xj/mj hood, faded but no major flaws. 20.00
4.0L intake manifold and throttle body from 89 xj. 20.00 (intake has been dry ice blasted and looks almost like new)
xj grill from 88 model, has one little fin broken at bottom. 15.00
(2) xj front header panels. In pretty good shape. 15.00 each
(1) 6 on 5.5" steel wheel. painted black, big center bore. 10.00
xj steering column. tilt, with wheel and key. 25.00
xj steering wheel dark grey from 89ish Very Nice! 10.00
set of D35 Non c clip axle shafts with bearings and plates. 40.00
set of Chry. 8.25 (29 spline) axle shafts. 50.00
chry. 8.25 carrier with 3.55 ring gear and spiders (29 spline) 25.00
clear front marker lights for 96 and older xj's. 15.00/set
xj headlights 10.00/pair
ZJ polly gas tank with sending unit 20.00
MJ long bed drop in bed liner FREE
XJ/MJ guage cluster from 89 xj. spedo, with out dummy lights. 10.00
(2) XJ/MJ brake boosters with M/C's 25.00 each
rear drive shaft from 88 xj 4dr., 4.0, aw4/231/8.25 25.00
stock xj/mj draglink 15.00
NP231 main output shaft and tail housing 20.00
Nuetral safety switch for AW4. 25.00
Diff Covers: (2) D44's (1) D35 (1) D30 10.00 each
stock xj air box from my 99 xj. 15.00
'89 xj rear hatch glass 20.00
4 aluminum wheel spacers for jeep pattern (5 on 4.5) They are 1.25" thick and I have the cone type nuts for them.
there are a few studs broken out of them but its an easy fix. Just punch the old ones out and set new ones in.
I bought them to use on my xj with stock aluminum wheels on the street but didn't go that route so I don't need them anymore.
100.00 for the set
100.00 for the set
