Alright, coming back to the brain trust for more help. I got the A/C manifold as suggested, and it was helpful. It confirmed that in fact, my low side I had basically zero pressure, and on my high side I saw it peak to nearly 400 psi before I shut it down. It kept creeping up to no end, which would explain why it kept blowing the relief valve.
I think the problem had something to do with this unique set of fittings and spring valves... not sure if that would be correct terminology. I'm almst certain that there is a problem with this setup, or by design it is supposed to greatly restrict the flow? I thought the only 'restriction' by design was the orifice going into the evaporator. Need help/explanation on this. The left end is the hose that goes to the expansion valve (high side) and the right end is what connects to the dryer/receiver.
What is this, what purpose does it serve, and how do I ensure it is functioning correctly? If this isn't the problem, it has to be the dryer/receiver.
Thanks for the help!
