josh89xj said:
My system had a bad leak and leaked all the r-12 out.I replcaed the leaking part and filled,thats going to be ok right?
NO its not going to be OK.
You filled it with R-12 or R-134a?
If you filled it with R-12, it sounds like you did NOT add any oil. There are specs for how much oil you should add for replaced part because the oil gets distrubutited in the system and thus some trapped oil is removed with the old part. As well, the oil mixes with the refrigerant and it leaks out with the refrigerant, so you should always add a little more than what is called for when replacing the part to get the oil level back up. There is no way to check the oil level in an AC system, you can only guess with some guidance from the book, so you should always guess heavy and add a little more than you need.
Your most likely low on oil for the AC system and it will wear out sooner, if not sieze up.
If you filled with R-134a, your in real trouble, R-12 systems use mineral oil, which is NOT COMPATIBLE with R-134a, the oil won't mix with the refrigerant and it won't get circulated thru the system, it will just lay at the lowest point and NOT lubricate the compressor.
Your system is going to sieze up in a short time.
If your going to retrofit R-12 system with R-134a you need to do your research. At the very least, you have to purge all the old R-12 and oil out of the system before you fill it with the
PROPER AMOUNT OF R-134a which is less weight than the original R-12 capacity and the
PROPER OIL THAT IS COMPATIBLE WITH R-134a. There are some retro-fit kits out there that have you fill the system with R-134a and POE oil, leaving the old mineral oil, don't use them. It may work for a while, but its likely to fail in short order.
The R-134a OIL is not Compatible with the R-12 Oil, so if you mix them, your oil is going to go bad. PAO oil is definitely not compatible with mineral oil, POE is tolerant of a little mineral oil, but if you mix POE 50/50 with mineral oil, the POE is going to bad after a while, as well, a 50/50 mix of compatible/non-compatible oil with R-134a is NOT going to mix and circulate as well with the refrigerant and lubricate the system properly. As well, that useless mineral oil is taking space that could be used for refrigerant that would help cool the system that has already lost cooling capacity from the conversion to R-134a.
You get the point, if your going to convert to R-134a, the only proper way to do it is too completly purge the system of the old R-12 and its oil. AND THATS ONLY ONE OF A DOZEN THINGS TO CONSIDER AND DO WHEN DOING A PROPER CONVERSION.
Also, R-134a is a smaller, lighter molecue with different pressure properties, you should only add about 75%-80% of the capacity for a R-12 system. Since the molecues are smaller and lighter, you get more molecues per Oz than you do with R-134a, so if you put the same weight R-134a in a R-12 system, you've overcharged it with to much refrigerant. Look up Boil's Law and refresh what you learned in High School, AC works off the Pressure/Temp relationship in a constant volume, using phase change in the refrigerant from liquid/vapor to gas. You'll see the number of molecues is what fill the system, not the weight/volume of the refrigerant.
(Check the 75%-80% figure, Its been a while) If you fill to the same R-12 Capacity with R-134a its overcharged and the pressures will sky rocket and you'll likely blow a seal, burst a part or burn up the compressor working against the super high pressures.
