The ball joint install did not go without issue.
Getting the old ones out was fun, they didnt come out w/o a fight.
First off the cotter pins on both lowers were rusted and seized in place.
Both of them broke off, and needed to be drilled out so that I could get the nuts off.
I know I know.... why bother if your replacing them anyways right?
Good question, I dont know why I did it. Just did it to do it, maybe did it out of habit, I dunno.
The uppers weren't MUCH better but still were better off than the lowers.
With the axle back in the garage, I bolted it all back up, as I knew that having it under the Jeep would give me the leverage I needed to press these things out. And press them out I did. Luckily I've got the tools, and the adapters and everything I needed to make this job a little easier than without.
Some of you may be haters and have nothing but bad things to say about the Harbor Freight 4wd Ball joint Service Kit. But I've had this for several years, and It's been used for countless U-joint services, and to date, 3 different ball joint installs, and more.... And it;s still working as good as the day I bought it.
It all comes down to using your tool the right way. :eyes:
Using the right tools the right way the old ball joints came out without TOO much difficulty. Yes I had to bust out the breaker bar and the BFH... but again, thats what it takes to do this, and knowing how much and when to do what is the difference between having a tool break, and having a tool last.
Old ball joints on top, new shiny on the bottom. (Alloy USA 11801)
The new ball joints were set in place, and pressed to their new homes.
If YOU end up getting the Alloy USA ball joints, be aware of how the lower ones are clocked as you press them in. Otherwise the access point for the grease zirk may end up pointing in a direction that would make service a little hard. This position is a little OVER clocked for my liking, but I can still get to it easy enough.
Minus dust caps ...here's a pic of the new ones all put in and ready for the knuckle.
Thats basically it, I'll get a couple more pics up later of everything all buttoned up and installed. It was getting late after everything was done, so I didnt snap any pics of the finished product and the gussets painted.
BIG thanks to Brandon (Bmikes) for the welding. And a special thank you to Wes (92WarWagon) for the assist as well. Glad to have you there for the occasional third hand buddy - it really made a difference.
All the help guys was really appreciated.
atriot:
