goodburbon said:
Can anyone else confirm this? I don't really care, it's only 20 minutes to change a set of injectors out, and I have a few sets lying around. one from a 97 , one from a 99 and the set of ford orangeish yellowish
injectors.
This is from Dr. Dyno's site:
The following is a list of the injectors used on the 4.0L since 1987 along with their rated static flow:
Model Year, ...Part #, ......Colour, .....Fuel Pressure, ...Static Flow,
'87-'90, ........53003956, ...Dark Tan, ..39psi, .................18.6lb/hr
'91-'93, ........33007127, ...Brown, .......39psi, .................21.0lb/hr
'94-'95, ........53030343, ...Tan, ...........39psi, .................21.0lb/hr
'96-'99, ........53030778, ...Grey, .........49psi, .................23.2lb/hr
'99-'01, ........04854181, ...Blue tip, .....49psi, .................22.5lb/hr
The injector flow rate varies as the square root of the pressure drop across the injector. The stock '91-'95 4.0 injectors are rated at 22lb/hr @ 43psi fuel pressure, so at 39psi they flow ( sq. rt.(39/43) x 22.0 = 21.0 ).
For stock/modified 4.0 engines or stroker build-ups the following injectors can be installed. The flow rates are:
Ford Motorsport 19.0lb/hr @ 39psi (Part no. FMS-M9593-C302)
Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302)
Ford Motorsport 30.0lb/hr @ 39psi (Part no. FMS-M9593-B302)
Chevy LT1 24.0lb/hr @ 43.5psi (Part no. 17124248)
Chevy LT4 28.0lb/hr @ 43.5psi (Part no. 17124251)
Accel 19.2lb/hr @ 44.1psi (ACC-150119)
Accel 21.1lb/hr @ 44.1psi (ACC-150121)
Accel 24.4lb/hr @ 44.1psi (ACC-150124)
Accel 25.6lb/hr @ 44.1psi (ACC-150126)
Accel 29.4lb/hr @ 44.1psi (ACC-150130)
The '95 Jeep 5.2 ZJ/Dodge 5.9 injectors (Part no. 53030262) are rated to flow 24.6lb/hr at 39psi
So I was off by a little on the decimals
