jeeperguy21
- Syracuse, UT
On New Year's, I finally replaced my leaking water pump with an OEM replacement pump & a 195 degree thermostat on my 99 XJ. Ever since I have done that, it seems like the heep takes a lot longer to get up to operating temperature.
It used to heat up really quick to 210 degrees. Now it seems to take much longer and it rarely gets up to 210. It now gets up to between 190 and 210. Since I didn't replace the pump with a "high-flow" pump, and the thermostat is direct replacement, what might cause this to happen?
