natixj
- Cincinnati Ohio
I have seen some threads on here about a wiring kit for older xj crank position sensor. I have a 98 xj 4wd I6, and im having problem with the cps it keeps throwing a code and the cel comes on. I replaced it with different brands of cps sensors, and still throwing codes. It runs ok there is a slight miss at idle but may be from plugs or wires. I have traced the wires back as far as I can but they get lost in the main harness with similar color wires and I cant follow any more. I seen posts about older xj cps low voltage problems and they talked about a kit to eliminate the problem. I was wondering if the same kit will work or if there is a different one for the 98.
This is what I found for the 88 xj on other post PN 83-100-066 Crank Position Sensor Patch
Thanks for any help,
Ben
Ben
