Specs: 1997 XJ 4.0L AW4
Long story short I developed a non cranking issue this weekend, and am having trouble tracking down the culprit. Here's the symptoms...
-Starter works fine when terminals are jumped, engine runs normal
-Cleaned NSS, adjusted to where the relay clicks both in park and neutral
-Bypassed NSS, still no cranking
-Jumped green wire to starter at connection and starter cranks normal
-Swapped in spare starter, no change
-Swapped ignition switches, no change
-All fuses have continuity
-Relay under passenger kick panel (top most of the three) clicks when key is turned
-Starter relay in the PDC under the hood does not click, but shows 12V to it
-Swapped relays in PDC, no change
Advice on where to start looking in the wiring? It seems like there's a disruption in power between the relay in the kick panel, and relay in the PDC.
Thanks in advance.
Thanks in advance.
