I got the idea from this pic I found over on ComancheClub...
I found the bracket on an unknown year model. I assumed it's was an HO model. All of the Renix models I looked at had an extra wire running to the booster rod mounted brake switch instead of this type bracket. It's off an auto trans model as well. It did have to be slightly modded to fit my manual pedal assembly...
...I ground off this corner and notched the opposite side corner. I also moved the switch in the opposite hole shown in the pic. I moved the mounting insert to the next hole as well. It's a little easier to see in this pic with it installed.
With the slight grinding I did the bracket slid on the pedal assembly and even lined up with an existing hole in the pedal assembly. The switch is this painless model is this one.
Painless Wiring 80172 - Painless Performance Push Button Brake Light Switches - Overview - SummitRacing.com it's cheap, and it can even be ordered through AutoZone.
I did have to tweak the bracket down a little to make good contact and maintain some adjustment with the switch. Then all you do is cut off the old plug and solder on a couple of female spade connectors.
