85xjwoody
- Little Suamico Wi.
Ten High said:"The PCM monitors the crankshaft position sensor. If the PCM does not receive a crankshaft position sensor signal within 3 seconds of cranking the engine, it will shut down the fuel injection system."
are you sure the pump isn't coming on at all?
I am sure the pump is not coming on at all. As said before, the pump works when you jump the fuel pump relay but not any other time. I always heard the pump as soon as I turned the key on.
Now I don't hear it, don't have any fuel pressure, don't have any spark at the plugs, no power to the coil, just plain nothing.
Having a dead cam position sensor would that have any affect on no power anywhere?
Kim
