jimsmith29841
- South Carolina
Ok guys this is whats going on..First thing is check engine light would come on every once in awhile and along with that the voltage guage would drop to 9-10 range....Then it happened more frequently...shutting the engine and restarting would sometime cause the check engine light to go off and voltage guage would read normal....So I am thinking the alternator is bad,,,,so I got a new one from Autozone and replaced it and the check engine light was still on as soon as I started my Jeep...So then Someone told me to do the Key On Key Off and get the codes....I got Code 41 which is "[FONT="]Charging system circuit-output driver stage for generator field does not respond properly to the voltage regulator control signal" Ok,,,,so what does that mean? I have search the web, but can't find out what needs to be replaced if I get this code....Any help apprecaited....
Jim
South Carolina
[/FONT]
Jim
South Carolina
[/FONT]
